Change rotate/move tool for mesh
I have meshes imported, but need to mirror and combine. Problem is, the rotation axis is at a weird angle and impossible to align the mirrored mesh. Any way to reset the move/rotate tool?
Hmm wonder if it’s possible to create a construction axis on the mesh. Haven’t work with meshes. Have you tried that?
You can give the Center pint of the move tool a slight sliding tap and it realigns.
You can, but this only allows rotate around axis.
Tried that, but not really changing to anything helpful.
