Moving model to center axis
I did a video that you can watch here: https://youtu.be/Ondbcm2NPVo
Basically wanting to know the proper way to orient a model differently than it was originally started.
thanks,
Glenn
I draw a circle in the center, and then another circle in the center of my object then use the translate tool to move it perfectly centered. Hope that answers your question.
The problem is that you are using the 3D transform tool, that does not snap at all.
Instead try just selecting the sketch in the default mode without switching to Transform, and simply drag the center point to the origin.
I don’t understand this answer. Perhaps a simple video explaining how this is supposed to work?
I tried that and it doesn’t go to the center. Even if i input 0 on both axis’, it isn’t in the center… no idea why.
