Connection between ellipse and circle
Hello, I am trying to form an intake tube in my front fog light and so i need to create a wall here to make this tapered pipe that will take it from the foglight ellipse dimensions (48mm radius x 43.5mm radius) to 3” intake piping (37.5mm radius circle). I hope this makes sense thank you in advance for advice.
Loft the ellipse to the circle or vice versa. Draw a circle and the ellipse and then use the move tool to move one or the other to the desired depth and then loft them. Then use the shell tool.
thank you i’ve got it formed now i appreciate it
