This purple line has appeared…
When moving the centre of the circle it snaps automatically to the lines and not to a grid point in between ?
Secondly using the offset tool only shows the value in the corner box and doesn’t show you physically moving the sketched line but the value changes when the pen moves but the sketch doesn’t ?
Carl
Should I be only working in beta ?
What’s everyone else doing ?
Carl
If the snap points are closer than the size of the tip of the Pencil, it’s hard to find the grid point. In this case it makes sense to zoom in a bit. This is not something that changed with the latest release, but it worked like this before.
Should I be only in beta now ?
Also, you can disable “Guides on selection” in the snapping menu in the bottom right corner. We have not released a new public beta. Use the App Store version.
Ok will do …
Thanks for the help
Carl
Hi Zoli
Can you help please I need to finish this work and now cannot duplicate copy or move these crates to
Can I send the file I’m working on please ?
I’m not a tech’y Guy and trying to find my feet
I make many mistakes and think it’s because I cut corners ?
Cheers
Carl
Hi Carl,
Please export it in .shapr format and send it to zoli@shapr3d.com and we take a look at it.
zoli
September 5Hi Carl,
zoli
Visit Topic or reply to this email to respond.
In Reply To
September 4Hi Zoli Can you help please I need to finish this work and now cannot duplicate copy or move these crates to Can I send the file I’m working on please ? I’m not a tech’y Guy and trying to find my feet
I make many mistakes and think it’s because I cut corners ? Cheers Carl
To unsubscribe from these emails, click here.
Hi Zoli
It says the file sizes exceeds and won’t allow me to attach ?
Carl
Hi Carl,
Can you try upload it to the cloud (Dropbox or Google drive) and share only the link with me privately?
zoli
