Construction plane and its local axis?
I made an construction plane on hexagonal prism,
and want to move it to opposite side of surface, of hexagonal prism.
As you can see; the distance between opposite side of surface is 10mm, I clicked the original plane > tried to move it with clicked “copy” > click the axis > insert 10mm in the blank.
but as you may have noticed, this doesn’t work, since the axis on the construction plane is NOT LOCAL one, but global one.
Some of you may say; Just click the surface of prism and create the plane! Why make an detour?
However, I want to let you know, it is a just a “demonstration” of my real problem.
My real problem is kind of complicated, but it seems that with this feature enabled - local axis on the plane when to move the plane - , then I can solve my real problem.
Am I not knowing the feature of enabling the local axis of plane?
Thanks.
