Copy and Move object certain distance
Hi All,
Noob question, any help would be appreciated. I am working to build a table made from aluminium profiles, and to make the drawer slides fit the centre of the tracks/grooves need to be at an exact distance/length from each other.
I have added a picture of what I am talking about.
Hope the picture helps.
Select the sketch elements you want to copy, select the Move/Rotate tool, click on the Copy icon, and move the elements using the arrow in the direction you want. You can type in the movement amount.
Thanks that already got me half way there. But, do you know if I can select a point on the object from which the distance is calculated?
Hi Rohan,
Try the Translate tool.
Thanks Bob that’s the ticket! Amazing tool that will really help me a lot! Thanks for your help!
