Copy and Paste for Sketches
Would be cool if you can further develop the copy tool. What i need is that i can copy and paste a sketch in another sketching plane. Is this possible?
Copy/paste is not currently available, but we’re looking into implementing that – the details are a bit tricky there. Since you wrote “further develop”, I guess you’re aware that you can use the Move tool’s “Copy” make copies of sketches as well, right?
Yeah i know but if i have a complicated sketch would it be useful to copy it if i need it on another place in my project an paste it in another sketching plane. It feels more natural for me an example on the iPad. Select a sketch, then hold it with the pencil click on copy, go in another sketching plane with another direction in space, hold again and click on paste. Then i could move it or snap it on another sketch or intersected body.
You are right, I understand. We’ll be looking into it, but I can’t make any promises about it right now.
If the planes are in line with each other, adding the option to “convert entities” on another plane would be a good solution too. The original sketch would drive the new sketch and you would select either the whole sketch or parts you want in the new sketch plane. But also yes, coping a sketch is sometimes useful if you need to make a slight variation as in the case of a loft.
I have this problem where I didn’t realize I was sketching into a different plane, and now my lines will not connect. There is no way to move the lines to the same plane. Very frustrating for an expensive tool.
If need be, create a construction plan on the destination sketch plane.
Then select the source sketch(s) and use Project to copy to the desired plane. After that you can delete the source sketch(s).
We still need this feature! And, it turns out, if I stay in the same plane - “Copy” during Move/Rotate doesn’t duplicate as well.
Given that sketches are not part of history-based editing, just make a good, old, plain, dull duplication will be OK, and will not break the philosophy of the process.
Thank you!
