Creating a 4 branch manifold with set endpoints
This is my first post so bear with me.
I am trying to design a 4 into 1 branch turbo manifold for my landspeed motorbike. The end result would be printed in 316 Stainless Steel. I’ve found various tutorials online but all of them dont have fixed endpoints and seem to be made with a 90deg bend.
My manifold has a 54deg bend between the exhaust ports and the turbo flange and each branch has a slightly different spacing between the ports.
I have scanned the original manifold so have the known endpoints for the exhaust ports and know where the new turbo flange needs to be but I am struggling to find the correct technique for creating a joining line between the 2 endpoints so I can use the sweep function. I have had some trial successes but its based on estimating where the joining line should be rather than using a proper technique.
Any suggestions would be appreciated. I’ve attached the scans, the design would be the same, I just need the single turbo flange in a different location.
Are you trying to achieve something like this?
If so, check this out.
Thats exactly what I was looking for! I had found a YT vid showing the same technique but without the detail.
I manage to get v7 of this complete, best yet. I extract it and when the STEP file is viewed in something other that Shapr3D, it looses some of its outerbodies/shell.
Any idea what causes that? I had something similar in a previous version but it the software it looks fine.
Thanks alot for this, I’ve been pulling my hair out for a week
Maybe relevant,
To repair my STL, repair shops are often too limited in file size and/or are too expensive (all with an uncertain outcome).
As STL always becomes error-prone after some non-trivial work in S3D my ordinary work path is to use FreeCAD: open the file in Mesh mode (you may have to Refresh and select), then Mesh: Analyze: Evaluate and Repair. Run each step individually: Analyze—Repair, but _not_ Self-intersections (most typically just mangles the STL). All over again until satisfied.
Fusion is an alternative, but it typically results in the STL’s horrifying death.)
After this most SLA printer software can do the final repair step if necessary. Lychee is good at this, is free, and exports STL
My 2¢
