When I want a new body I first have to position the camera, then sketch a rectangle in a meaningful position, and then move the camera, and then extrude it. Creating a centred cuboid or spheroid should single-step + click process; the default cube (or whatever) can then be tweaked to the dimensions needed.
I don’t know, seems kind of redundant to me. Seems to be same amount of steps:
Create Cube → Input Dimensions
Or
Input Dimensions → Create Cube
Creating a cube under the status quo has multiple steps, including:
- Camera manipulations in preparation for the initial sketch
- Selection of the appropriate sketching tool
- Creation of a 2D sketch,
- Camera manipulation to bring the extrusion handles into view, and
- An extrusion
…after which the body is probably manipulated/sized further anyway.
Creation of a new body in the default position could and should be a single step. For example: keypress + ENTER.
Oh, you’re talking about the Windows version. On IPad it’s pretty quick because of the pen.
I can definitely see the use in a hot key for making certain shapes, great idea!
MacOS, but yeah.
