Creating a sketch from an extruded model
I am exporting SVG files from Shapr3d to be used to cut items out using my Shaper Origin router.
Sometimes when I make a complex design and extrude it in my model, I dont have a sketch of that design, and need one to be able to export as an SVG. I then have to go in with the line tool and manually make one, which is tedious and not always accurate
Is there no way to simple pull a sketch from a 3d extruded model?
I would create a offset plane from object and then project object to plane, you would then have a sketch.
