Creating a smooth transition using the loft tool on a curved edge
Hi all,
Is there an easy way to use the loft tool along a curve?
I’ve tried to create a number of planes on the curve, however, I’m not getting a smooth transition as I would on a flat surface. Is there an easy way to do this in Shapr3D or would I need to do this in Blender before exporting back to Shapr3d?
Thanks in advance.
Desired shape outline:
Example:
Example flat surface:
You mean something like this?
You already have the guidelines, so when you press loft: select the bottom surface and the horizontal surface and then select both the curves on each side.
Look at the tooltip for loft if you need a reference :slight_smile:
