Hi!
I’ve tried modeling a shrimp’s carapace using the loft tool combined with a guide curve but I keep getting this error message:
“Fault detected in a guide wire”
Any idea what may be wrong?
Cheers!
Hi!
Cheers!
Hi, Can you please upload the Shapr3D design? I guess the guides may not intersect properly with the cross sections, but checking the model would help a lot.
Thanks for the screenshot! There is another thread with the same content, even dough it was started with the sweep tool ![]()
When using the guided loft, please make sure to have a closed cross-section at the start and end points of the guide curves. In the other thread, I shared a video that I think could also be helpful for you too.
Thank you! I will have a look ![]()
