Hi, I’m having an issue with the translation of some (not all) of my holes/cylinders into circles when creating drawing from my model. Some of the time it translates perfectly as a circle with a dimensionable diameter, but often it translates as a broken circle with line points that either force a radius dim instead of a dia, or won’t allow an angular dimension at all. As there seems to be no way to control the projection or to draw over the line with a ghost shape, how do I fix this so that I can properly dim my drawing?
NEVER MIND! Figured it out. My holes were .001 degrees off 90.
