Hi, I can not pick the circle to show the value.
What am I doing wrong?
Thx
@Solid3D
Thx
@Solid3D
Hi @Solid3D,
Projections for the Drawing tool are made according to the coordinate axes. If the axis of a projected hole is not parallel with the projection vector, the projected result will be an ellipse.
Apart from that, there are some other possible reasons for this case. Can you please tell us a few words about how the hole was made?
Peter
Is your orange arrow pointing to an image? That’s what it looks like.
If so, you need to Sketch a circle on a plane above that image and your value can be seen when selected.
Hi TigerMike and KPeter,
I have upload the file. The original file is from Solid Edge and saved as STP.
I have imported and made some features in Sapr3D (rounds).
Thank you in advance.
Best Regards,
Petter
Fot til Horn, rev.1, support.shapr (435.6 . KB)
When, I have made the drawing I can’t pick the hole
Thx, I did a test in Solid Edge and it worked.
The original file had a cutout that had an ellipse
Cheers,
Petter
