Designing from a photograph
Hi Guys,
Is it possible to design using a photograph as a reference that has been imported into Shapr3d? How do you you deal with the perspective/distort of the image etc.
Best Regards
Tanker
Hi, yes you can use an image as an outline for drawing your sketch. You can double-tap on the image to have it on 2d mode for a better perspective and then adjust its opacity. Here’s a short video on sketching using an image as an outline:
We had a webinar about this topic, I hope this helps: https://www.youtube.com/watch?v=87_LIVDjuF8
Many Thanks Guys,
Your info is much appreciated. Looks like I will get it to work.
Best Regards
Tanker
