Dimension on Assembled Model
Hi All,
I would like to request some advice from here when I tried to create dimension on a Assembled Model.
Have anyone experienced this and do share with me how it can be done.
Thank you
What is the problem you are running into? If you select the two faces you want to dimension, it should simply show up.
It works on IPad.
But doesn’t work on MacBook Pro.
What happens when you select both? You hold down Shift while selection right?
Cool. I had tried the “Shift” key and it works.
Thank you very much for your advice.
