I would suggest that you work on a copy and just experiment with the changes and additions. Good luck!
Hi, Just as @tommyn mentioned you can make a copy and then try editing the duplicate body using the boolean Tools(intersect, subtract and union)
You create a new body with which you can use to edit the design.
Here are some of our great short videos on the boolean Tool operations:
