Drawing sheet, bug IMPORT / EXPORT
Hello, I’ve just noticed an issue on my iPad M4 Pro. When I create a drawing in a project, I no longer have the option to add an image from the Files app. Currently, I can only add images from the Photo Library. I am certain this worked before, as I previously used it to add company logo and stamp to drawings.
I have also noticed that I am unable to export drawings to PDF via the EXPORT section on my iPad. Although the PDF export option is available and I can select it, the ‘EXPORT’ button in the subsequent save window remains greyed out and unresponsive instead of turning blue. I have to close the window and select EXPORT/PDF again. Even then, the only way to make it work is to tap the share icon and then select ‘Save to Files’ from there.
