Editing 3d model
new to shapr3d, ive designed a bracket in 3d and need to make adjustments to the location of the holes how do i move it around and connect it all together. thanks
Hello, first select the part which you want to move. You will see some arrows and with the help of arrows you can move your part .
Try selecting the inner and outer faces of your holes and use the move tool. Simple holes can be moved easily this way.
