I need to move the object to contact the objet below it but when I try and move it the arrows and dot that normally would move the arrows moves to the object doesn’t. My SHapr3D is updated to newest version. BTW The new selection coloring tools are great!
With the screenshot it’s hard to say why it won’t move.
Thing that’s odd is icon on the items list of what you selected as point in the middle of the icon. Is this a imported file? Also you have some errors in the history.
If you can share the shapr file someone can try it see what’s going on.
The edges are shown with black, it looks like only the faces (side, bottom, and top) are selected on the cylinder. Moving them without the edges would not maintain a solid body.
To select the entire body, double-tap/click on it, and the entire body will be moved.
Really? I thought it either deforms or moves.
I ended up deleting the body below what I was trying to move and making another to fill the gap in the middle. The reason for the errors in history is because I’ve deleted some bodies, sketches and planes I no longer will use. Is there a way to delete history?
