Embed or emboss a logo into shaper
Hey there fellow designers / makers im looking for some guidance and help? Is there any tool or process where i can upload a logo image into Shaper3D to then emboss or embed it into my part? I’m familiar with the Solidworks process from illustrator. Thanks for the help in advance.
@krazykanuckjr Currently there is not a native way of doing this. It may be possible but certainly not in an automatic way like other modeling packages.
Hi @krazykanuckjr Welcome to the Forum.
Is this what you are looking for:
https://discourse.shapr3d.com/t/flat-to-round/6081/2
Obviously different effects will result dependent on the Body being Projected to, and relative to size and shape compared to the Logo.
Happy S3Ding.
Im pretty sure that tool will help especially with a curved surface. will use that next time today i simply spelt out the company in sketched blocks than extruded it all. May the modelling be with you.
@krazykanuckjr
If it gets you moving in the right direction it is a start, if you experiment you will likely get the result you want. Hope we can look forward to seeing your Designs.
