Making a logo 3D
Help!
Hi im new to Shapr and Im on a pc trying to take the black of the logo and make it a 3d part to make a key chain
Like this person
(https://www.cgtrader.com/free-3d-print-models/gadgets/keychains/customizable-logo-keychain-stl-read-description)
Hi and Welcome !
You can download .STL file with your link to cgtrader.
You can import it in Shapr3D. But It will be a mesh object.
The other solution (the cleanest in my opinion) will be to redesign the logo (sketch) and extrude it.
You can import the original image to use as a template.
You can do auto image trace, both in Inkscape and Illustrator. I did it quick in Inkscape you should download the software and fine tune it.
It’s a DXF file forum makes you zip it.
logo.dxf.zip (39.9 KB)
Your method is the best way :slight_smile:
Here is very quick hand made variant, spline and other primitive used to recreate
