Hey all. I’ve got a project where I need 16 points around the circumference of a circle. There’s another circle inside of that one and that should have the same amount of points. How do I spread points or lines equally as in the drawing attached? Thanks a ton.
Use the Pattern tool.
Hey there. I’ll give it another go. I tried earlier with a line I made from the center of the circles. The pattern took just rotated the additional pattern lines around the line I made. I’ll check out what you sent and then try again. Thank you.
I just left the gym and watched this video. I see what I did wrong. I trimmed the line I made so that all that was left of it was the line between the two circles. When I ran the pattern it just spin on itself between the circles. Thanks a ton.
