Model when exported doesn’t show full. I’m opening in mesh mixer but have tried other applications with the same outcome. Basically the top where the holes are is missing. New to this program but have used cad in other applications. Thanks in advance
Can you post a screenshot of the exported model?
Which format are you using? High quality STL?
high quality stl.
I have sent you the fixed file, the issue will be fixed in the next release. Thanks for reporting it.
