I’m trying to export a sketch as a DXF file. However, no matter what I do, the end result is a single collapsed line with no dimensions displayed properly.
Apparently, as a “new user” I cannot attach files…
Will appreciate any help and/or corrections as to how to export properly.
Could you please share the file?
If you’d like to do it privately, send it to our support portal: https://support.shapr3d.com/hc/en-us/requests/new
Hi
Have you try to export to DXF as Drawn ?
A temporary solution to the problem suggested by support is to move a sketch along a z-axis (the distance does not seem to matter). This helped me for now.
Yes it dose work for a DFX file. I had to move it off my Y and X the Z dose not show up in a DFX file. I hope there is a software update soon about this problem.
