Extrude or Inset Projected Shape on Cylinder at an Angle
I’m looking for a way how to extrude or inset shapes projected onto a cylinder but at an angled bevel (all sides). Similar to how when you extrude a sketch on a plane, it gives you an option to angle it after. However, on cylinders or other curved surfaces it doesn’t give you an option. The only way I found so far which is super time-intensive is to loft a smaller and a larger shape along the cylinder.
There’s gotta be a simpler way to do this!
Without thinking too much, I will use:
Tools > Project
Tools > Object Face
Transform > Scale > Non-uniform
or
No Project
Just Tools > Extrude with Draft Angle
