Feature Request: Thread Tolerance / Clearance Adjustment
It would be great to have a small additional setting in the Thread Configuration panel that allows users to adjust thread tolerance or clearance.
For example, users could specify an additional clearance of 0.1 mm, 0.2 mm, or 0.3 mm for 3D printing applications.
Ideally, this could be applied independently to internal and external threads, or to both.
This would be particularly useful for FDM 3D printing, where printed threads often require additional clearance to compensate for printer accuracy, material shrinkage, and dimensional variations.
Having this option built directly into the Thread tool would eliminate the need to manually offset thread geometry after creation and make the workflow much more efficient.
Thanks for considering this improvement!
Coming next release in a week or so.
