' Flip image orientation
To Flip image orientation ’ I tried the move/rotate selection and tt seemed t give me the right option gut it then gave me a message about a constraint or something stopping the action. So any ideas how to find out which constraint is the problem. I don’t understand why the offending item is not highlighted for attention by the software!
I just want to makethe top point to the bottom and the bottom point t the top r
I don’t want to do this manually with finger because then I can’t use the-cross- sectiontool which only appears to work in front view.
Select the elements and use the mirror tool
Yep, that worked thanks!
