Formulas and variables to set pattern values
Using variables and formulas with pattern tools
  • getting closer to fully parametric designs *
  • I want to have a pattern that will add length and added pockets to a part base on the length of another none pattern feature.*
  • a second related feature would be to allow a constrain of the last piece in a pattern to another feature, so if that other feature changes, the pattern changes with it. If the pattern is set to a specific spacing, then it will auto add pattern features, if the pattern is based on over all length then it will just change the spacing while maintaining the number of the pattern*
  • ORRRRR both the options would be idealL*
