I’m trying to create an irregular circle and turn it into a printable object. So that,
- It is round but not circular
- It isn’t a disc, but an actual circle of around 1mm thickness
Do you create two odd discs on extruding the other, or is there a way to turn the gap between to circles into a surface?
Is there a tutorial on how to mirror a spline to create a surface?
