Spline to smooth surface
i want to make a smooth surface with the shape of a spline, as if extruded at right angles to the spline’s curvature. or like a loft between two copies of the spline. how might this be done?
objective is to slice the object below along that curve
@RonJeffries
Is this the sort of result you want:
If not please explain further.
yes if the cut is a spline and not just a plane.
The Spline was Sketched on a Plane above the Body
Then three Lines were added to the Spline to form a Closed Curve:
Highlight the Closed Curve and drag it downward and through the Body in one movement:
super. thanks. i feel i should have known that but these tools aren’t second nature yet.
thanks!
