Where are the Union file/models located when you do a Union with the option to save originals selected. I Unioned a part and I can’t locate the Unioned part. Thank You
Hello,
All the bodies used in the Boolean tools will remain in the same workspace at the same place. If you have Keep Originals turned on, the bodies that you applied the booleans on will cover the original ones. To select them, please use the Items Manager
