How do I lean/angle a wall?
I have an object with a floor, and 3 walls. I’m trying to angle the wall or lean it back to 45 degrees. I’ve scoured the tutorials but can figure out this function. Any ideas
Hey @EVfan, can you show an image of what exactly you need?
IMG_87336C3C3D6D-1
I’m trying to make the top of the wall with the slots in it meet inside edge of the rim I created, while the bottom remains in place. Essentially making the top of the box 30" long, and the bottom 20".
IMG_0562
I’ve got closer, but now need to get rid of all the stuff inside the box, so it’’’ get back to 3 walls and a floor.
You might try drawing it upside down from your depiction and as a full box on the lip which is shelled out and the slots extruded through. Then just rotate the face with the slots to the desired position. Seems like a simpler approach to me. Hope this helps.
