How is it draw a fuselage front end
Here is sample to draw an organic lofted body.
I have three kind of version.
“Stepped back”. :
“ Rounded back” :
and long ended :
The first of two need more feature and experince to draw to finish.
But both of three should be welcome the guided loft and “dome” feature .
The target is a mould form:
Here is two link from the drawing:
https://youtu.be/KG2N-gM8mYg
And from the loft
https://youtu.be/xPQkCAeFC24
Brg
A
Nice work! Thanks
Nice!
What is you rendering app (the two first images)?! It looks nice.
3D pdfreader its work on ipad, also with dropbox. Very easy to use!
3D PDF Reader (fejlesztő: Tech Soft 3D)
Wow! It’s amazing. Downloaded, tried and trusted. Has slicer planes too, to see cross-sections.
:+1:
Welcome
A.
The parts completed with CNC machine, next step to get glossy surface.
The drawings 100% Shapr3D. Looks everything is good , will see after the first release from the mould🙃
Very nice work! Looking forward to seeing a molded piece…
I work on it, some process left to go🙃
The first realese from the mould and making the silicone core.
The designed mould is working , looks perfect and shiny surface.
Some lay up test coming.
Well done, looking very good, are you using rtv for the silicone. Cnc 2 part mold looking very clean.
Yes, rtv2 addition curing silicone. On the first picture selftape wax sheet inside.
The polishig selfmade, handmade, 800 to 2500 water paper, after liquid polishing, then pasta with diamond powder to 3 micron. For the product shiny surface is neccesary a good quality realese agent.
Hi, new member here, plug looks awesome! I would appreciate some info on the CNC system. Many thanks, Christos.
Hi Chris, I draw it on S3D, saved to .step file and sended to te CNC worker, paid for it and get back the ready mould🙃
Opening the mould
Very nice — when will it fly?
It’s already flying😎
Here is a picture with the part full filled with servo’s & electronics without wings.
