How to add a parallel construction plane that touches the edge of a circle?
Hello there,
I am currently struggling to add a construction plane that is parallel to one of the main planes and touches the edge of an extruded circle (see picture).
I thought about using the offset face option, but for this I would need to know the coordinates of the centre point of the circle, which I do not.
How could this be implemented? Thanks in advance!
You can create a construction sketch at the radius of the cylinder, and create a construction plane that’s perpendicular to the sketch.
It worked for me by creating a construction plane using “parallel to face at point” with the centre point of the cylinder and then moving it with the value of the radius.
