How to draw an Hexagon..?
I want know if you have any option to draw a regular shapes like an hexagon. is any easy way to do that…???
Best Regards
Felipe
Draw a line, set it’s length to 1, draw another line starting from the end of the first line, set the lentgth to 1, and the angle between the two lines to 108 degrees. Do this 6 times and you have a hexagon :slight_smile:
But with the 2.0 release you will have dimensioning and constraints, that will make this even easier.
Thanks i will try, in solidworks you type the number of faces do you
need… Something like that. Shapr3D really amazing app.
