How to make a birdsmouth
Hello. New to CAD and Shapr3D, but having a blast. I’m designing a wood & storage shed, with a mono pitch roof. The roof joists will be 2x6s sitting vertically on a 2x4 double top plate. I want to design the birdsmouth cuts into the underside of the vertical 2x6s, so they rest on top of the 2x4 top plate - but can’t figure out how to do it. I know how to copy and use the Pattern tool to repeat them once done. It’s just getting the first 2x6 birdsmouth correct.
Talk to me like I’m a 3rd grader struggling to progress to 4th grade… :smiley:
Thanks in advance!
Welcome to the forum.
I made two 2x4’s (1-5/8" x 3-5/8") and an angled 2x6 (1-5/8" x 5-5/8"). I did not include the fillet radii on the pieces.
Place the 2x6 on the two top plates and do a Subtract. After that you can use the Pattern tool to make copies of the 2x6. I spaced them 16" apart in this demo. Hope this helps.
A short awncer, If you have the wall framing up, you can place the rafter where you need it and use the subtract tool.
Or you can use a rafter table and do it just like you would in real life. Whenever I do stringers I do it just like I would in real life. And then use the align tool. You can then use the pattern tool to add the additional rafters.
Also I use shapr as an onsite calculator from time to time, it’s really powerful for getting sq footages. Just don’t bring the nice iPad
As a visual learner, the video was perfect for me! Thanks for taking the time to do that. Works perfectly now. Cheers!
A lot easier in Shapr than in the field, unless your only job is rafters. And often on track home projects you have a small crew who’s only job is rafters. You have a stairs guy or two and a couple layout guys. That was the old way. The new way is all prefab.
Glad to help. I too am a visual learner and definitely a ‘right hemisphere’ person.
Reach out if you have any other ‘how to’ questions regarding Shapr3D.
Well. My next project will be interesting then. Building our own home (doing as much of the work as we can, ourselves). No significant construction experience - and no, I don’t have a death wish:D
If it’s your first, best not to build it for you, but rather for potential buyers market. Mistake a lot of people make and run out of money near the end.
