Im trying to make a wall that sits at 75° and also is curved how can I achieve that ive been trying and failing
I’d be interested to learn how, using Shapr3d, I could create a flat surface of this profile so the wall could be cut out of a sheet of ply.
my specific interest is to create templates of boat panels.
Apparently I can’t fathom how to use the sweep tool
It has some limitations. Simply draw any line, or connected lines. Make a construction plane on a point on a line. Sketch your profile on that plane. Jump out of sketch mode. choose the profile. Choose sweep tool. Then it prompts you to select the line (path). Keep selecting lines if they are connected. Click the “okay” check.
You can make picture frames with this method.
