How to Smoothly Round the Corners of a Rectangular Fence?
The image shows the corner section of a rectangular fence where it bends. I want to create a smooth, rounded transition at the corners, as indicated by the red marking in the image. Is there a way to achieve this in Shapr3D?
One way would be clever sketching on a single plane and rotating radius segments.
Tried it
I would project an arc of a circle on the surface of a portion of a sphere and then sweep along it. By doing so, you will get good curvature continuity because the sweep will be on the surface of the sphere and you can edit the 3D curve simply by editing the circle.
The video shows the simple process of doing it.
