When translating along a wall, how do you translate the item along a line? I want to snap it to a corner, but it always seems to shift up or down slightly. There is no guide like when I’m sketching a box. The only way that I can figure out is to create a construction plane perpendicular to the wall at the correct height and translate to the corner.
Hi, there is no dedicated tool in the app for linear translation at the moment.
Another workaround can be to draw a sketch on the corner face you want to translate the body to and then use the centre point of the sketch as a reference for the translate end point.
