Moving Sketch to Defined Plane
Hello,
I would like to move a sketch exactly to the origin, i.e., align it to an xy construction plane. Is this possible? I cannot seem to find an easy way to do this simple operation. I can only move the sketch a defined amount, not to a certain point or plane. Align only works with bodies. Screenshot shown below.
Also, another related question: Can I move parts of a drawn sketch into another sketch item such that they can be hidden for certain extrusions and then ‘unhidden’ to do other operations later?
Thanks for the consideration and help!
Scott
You can use the Translate Tool.
Select the tool, double tap your sketch and then select the two points.
You can select around the origin and then move it towards the origin and it should snap to it. (Same thing if you want to snap to the middle of your sketch)
Translate is useless if you want to get two sketch planes on the same zed height?
