How would I create a skewed pyramid like shape
IMG_0166
I’m trying to create something like the photo above. I’m able to create a pyramid but not skewed like in the photo.
Any help is much appreciated.
Hi Rodi01
Welcome to the forum.
I would simply create two sketches of two faces and use the loft tool between the 2 faces.
Any set of two faces should work.
There are many ways to do this. @PEC’s suggestion is straight forward. Others will offer different approaches. Here’s one.
Here’s my 2 cents…
I simply create the base profile I want then extrude it to the required height before moving the edge back to the ground plane.
Wow! So many different ways to get this done. Thanks for all the help, I’ll try them out and see which one fit my needs.
