I’ve drawn a fairly simple piece using a sketch and revolve. I was trying to set the transparency and noticed that the image colour and/or brightness is fading in and out. I made a 12 second movie clip from a screen save that I’ll try to attach.
Any thoughts?
Gerry.
IPad Pro 2 Max memory
Hi Gerry,
I dont see a problem here. When you select something this is the intended behavior, it pulsates to signal you that it is selected. - Daniel
I didn’t know that; thanks Daniel
