Implement horizontal/vertical constrains for points in sketches
If you draw 2 circles and would like their centers to stay horizontal or vertical it is not possible by simply adding a constrain.
The same applies to vertexes of non-perpendicular corners.
The workflow would be streamlined and a little more intuitive in my opinion.
Many other CAD-systems also support this, for instance:
  • FreeCAD
  • Alibe Atom
  • SolidWorks
  • Autodesk Fusion 360
  • Onshape
That makes this functionality kind of standard of the industry.
What is is that you can’t achieve without this feature?
  • Working without this function irritates my personal workflow.
  • Coming from one of the CAD-Systems above that frustrates and lowers the UX
  • as a workaround I could add a construction-line or -axis, but that makes the sketch a little less lean and clean. The less elements we need in a sketch, the better it is!
If you need additional Information, let me know it.
Cheers Matt
Good point.
Currently the best way to do this.
