Import multiple STL files
I need to import over 50 stl files into one project. They should also be indicidual objects so I can move the different parts. Is there a way to import them without loading them all individually?
I’m using Shapr on iPadOS
Hello Jan1, in your desired files manager, tap select and drag your finger across the STL files. It may take a minute or two to load them all depending on the iPad you use. I hope this helps.
What about for windows?
