Hi, I just started with Shapr3d and have a quick question. Is an import function for 2-dimensional arrays supported ? I am attempting to sketch a precise airfoil based on existing exact x y coordinates. The coordinates will be provided in a simple text format and should be mapped to points in the defined plane in Shapr. The points will then be connected manually using splines.
Thanks !
Hi i think cant do it.
My sulotion was to draw an airfoil in another CAD system ( from dat file) and and make a solid body like a tamplate, save as step format , you can import it .
In Shapr3d you can project to any face, and work with it , translate, move,ect.
Thanks for the quick response.
