In valid selection while trying to select a face in shell tool
I am trying to do Day #5 in Shapr3d tutorial which is supposed to make a 90º tube,
I cannot select the appropriate face in Shell tool. I get an invalid selection message. I can select the face when not in Shell tool. What am I doing wrong. Screen shot of item provided. The face(s) I am trying to select is the circle. I can select the body.
It looks like you have a sketch on that face. Hide it first then do the Shell.
Thanks, it worked except I’m having a really difficult time getting shell to work reliably. Here is a tapered tube I am trying to model. I lofted it okay but I cannot select the faces at either end. I have the sketches, 5 & 7 turned off but I still get invalid selection. I can select the faces just fine when I’m not in shell mode to extrude them or move them. What’s the secret to being able to do this consistently? I suspect the circle dimensions being there are a clue but when I turn off the sketch in item manager the sketch tool comes up. When I turn off the sketch tool the dimensions come back. I know it shouldn’t be this hard! Help is greatly appreciated.
Because you are selecting the sketch, not the face. Hide the sketch first, or isolate the body.
Thanks mate. That was very useful.
