Input different measurement
One feature I’d like to see added is to be able to input different measurements types. For example if I have the file set to millimeters I’d like to be able to use inches and it would automatically convert it to millimeters.
Cheers
Thank you @carlosporto for the feedback. As we will add variables and expressions to input fields automatic unit conversion is something that we consider as well.
FYI, Fusion 360 does this by allowing you to suffix the magnitude with the units, i.e. “in” for inches or “mm” for millimeters; others might be available, but those are the ones I use.
That’s how it works in most CAD systems, it will be very similar in Shapr3D.
