Invalid Bodies when try to export
Hello community,
I created for different objects within a project. ONCE I tried to export them to stl or 3mf, I get the message that the export has failed du to invalid bodies in my project. I have already searched in the community but did not found a solution, even if others ran into the same issue.
I attached a Screenshot of the project to the ticket.
Thanks in advance for the support.
It may be that your objects are too small. Could you attach a screenshot with some measurements, especially of the thread part?
It may also be that your geometry is just to complex at some point, which makes it hard to transcribe that in 3mf. You could check the parts where you think the parts are complicated.
Also, it is always good to check your history for errors, just in case.
Good Luck!
Thanks for the help. I tested and found out that I could export the project when I Remote the threads but that is obviously not a solution. I opened a support ticket and the support team. Was able to export. Theo also Worte that this is a known issue and that the dev team is woriking on a solution.
