There are invalid bodies in the model that cannot be exported
Hello, I’m receiving this error when I try to export my model to STL or SMF. I tried deleting the fillets which did not help. I tried deleting the mesh bodies I had imported into the model with the same result. Is there way to tell what shapr is finding invalid, or at least a way to tell prior to running the export and finding out then which is pretty annoying. To be clear it will not export anything valid at all, Cura says its corrupt.
I will add I also recreated the sketch to receive the same error. Its not really complex, its a triangle stand for a plaque. I was down to just a modified triangle at the point of the last error.
The limitation of the free product for 2 files is really rough for someone trying to learn CAD and your software, adding to frustration. I’m just a hobbyist trying to learn something new.
Hi @Duder! Could you please upload some screenshots of the model you cannot export?
I just re-did it entirely in a new project and it worked. The reason was because I was designing multiple things in a single project because like I said I’m trying to learn stuff, and see what I can do but limited to 2. I would think the low rez export alone would be a deterrent from remaining in free mode as it turns circles into Octogons when printing. I do appreciate your reply anyway.
If you have a model with many bodies and you want to find out which bodies are invalid. Try selecting all with the selection body tool. The invalid bodies will not be selected in this option. This is at least how to detect which bodies are invalid in a complex assembly
That’s a good tip @sander , :+1:
I still have the same issue :confused:
Any help please
Hi and welcome !
Not easy to answer without screenshot or shapr file
Hello I have this same problem when exporting too … can you help me? I left you my .shapr file. Being a new user I can’t leave a .shapr file. I leave a wetransfer open I hope someone will read me by then. Thanks
I have same issue and it’s my month of work, I am trying to export to 3mf file. I did try suggested tips to select all body and the one have issue will not selected in my case all body is selected please help
I have found the body but I could not understand what is the issue?
Please help this is file
F22-50x2MMhelp.shapr (19.8 MB)
shapr3d_export_2025-01-26_15h20m.3mf.zip (4.5 MB)
I converted to 3mf, mostly its Shapr export being finicky.
Shapr sometimes has problem with 3mf and STL, not sure why most likely a bug and nothing is really wrong with your models.
Hi @aqkhana2002, Nice model!
I could not directly export your file. However, when I relaxed the tolerances in the “custom” settings, it would export.
F22-50x2MMhelp.zip (16.0 KB)
Ok resolved it , I cut in slices and the foung the exact place giving error cut half and delete the problem one and the create mirror
It must have taken some time to model.
Hopefully you might show the finished plane in the share your creations category.
Goodluck with the build, and I hope it flies well.
I tried that - all the bodies selected, but it still doesn’t work.
What is not working exactly ??
